marcosoul
Jul 10, 2016Guide
Nighthawk X4 performance drops
I have been experiencing random performance issues with my Netgear Nighthawk X4 router. I have very fast internet speeds (160+mbps) but if I load several webpages at once (eg. 5 at a time), they get ...
- Jul 13, 2016
Hi marcosoul
Welcome to the community!
Have you tried changing the wireless channel?
If you have the NETGEAR Genie installed, see the best channel to use.
What's the current firmware installed on your router?
Try to adjust the CTS/RTS Threshold and Fragmentation Length to 2304 under Advanced Wireless settings.
ElaineM
Jul 13, 2016NETGEAR Employee Retired
Hi marcosoul
- marcosoulJul 25, 2016Guide
After preforming the steps you suggested, I have not experienced the "page loading" issue that I had originally reported. Thank you for your feedback ;)
