genes161's avatar
genes161
Nighthawk X4 R7500 AC2350 DNS problem
Can someone pls help me?
When I turn on "Enable Access Point Mode"
I get this dns problem and cant use the router. I can only connect to the second router that I have in my network.
The nighthawk is the first router and the other router that I can connect to is the second.
  • plemans's avatar
    You need to have something on the network controlling dns/dhcp/net.
    so if you put a router in AP mode, it disables all that and it relies on a different router to control it.
    so it needs to go modem/gateway/routing device------>router in AP mode
    And the device in AP mode, needs to come after the router managing it. Not before.
    • genes161's avatar
      genes161
      So, on the first router, my Netgear, this box gonna be unchecked?
      • plemans's avatar
        correct. the first "router" connected to the modem should be in router mode. 2nd one should be in access point mode.
        What is your full setup?
        What modem/gateway do you have?
        then what router?
        Then you're connecting the r7500 to that router?
    • genes161's avatar
      genes161
      Thanks, but...
      I want to change my dovado to ap mode... that is what I need help with.
      Pls read from the top.
      • FURRYe38's avatar
        Contact the Mfr of that device for help and information regarding there product. They will have what you need.
