Sodaman005's avatar
Sodaman005
Nighthawk X6 3200 router - cannot connect
I have an Internet connection that I have checked going into the router, my Wi-Fi shows that it is available, but when I connect, it says there is no Wi-Fi connection
    • FURRYe38's avatar
      Is this the R8000?
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
      Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
      Turn off and unplug modem.
      Turn on computers and rest of network.
