StagByTriumph's avatar
Apr 06, 2023
Nighthawk X6 AC3000 Tri-Band WiFi Router Model R7900
So my AV's have been bugging me to update my Router FW.
Win11,
HW Version R7900, updated to
FW Version V1.0.4.46_10.0.53
GUI Language Version  V1.0.4.42_2.1.44.1
So I decided, heck maybe a year later after experiencing apparent blocking and lots of latency to the internet there was a new FW that did not cause latency in my R7900 early version.
I downloaded R7900-V1.0.4.46_10.0.53, the latest available for my model and version. but still appears to be the same FW as I used last year, and after REBOOTING with the latest FW, the same old latency returned, and my Outlook would no longer send/receive emails.
So I flashed back to the previous FW version
Firmware Version V1.0.4.38_10.0.50
GUI Language Version V1.0.4.38_2.1.44.1
for my router an voila, instant emails and no delay in any internet.  I'm thankful that at least Netgear gives the ability to downgrade.
I paid a good price for this router and it has run reliably for many power on years- maybe 6 or so, but I have had two DDoS attacks in the past 6 months, my ISP Xfinity does not have any idea what DDoS is or how to detect and block them before the gateway because there is no technically competent staff running detection software or understands Indicators of Compromise, I cannot upgrade to the latest router FW because it basically kills my email access, so it is time for a new unit that will allow firewall rules and ease of configuration.
Progress of needing to update technology, but why, when this router supports IPV6 should it not have the capability to do much more and receive more FW updates that are not 2-3 years old?  Retorical question - don't bother with an answer, just venting.
It is very curious, no routing restrictions are placed with the latest FW, no port blocks, no restriction on sites, no blocked sites, just FW update with everything wide open.  If I had any decent detection software to report the DDoS, maybe I could start blocking it, if more detail to specifically allow traffic to and from my email service (yeah, tried those rulesets too)
Fortunately my AV's and PC setings have been able to keep Malware from wiping my files and stopping the attacks on my pc, for now.
Time to check out the competition or at least secure new products if I am going to again shell out +$250 for a secure and reliable gig speed multiband router that also has user configurable, allows easily settable rulesets, provides some edge firewall capability like running Snort, plus AntiVirus - interoperability capabilities.
Don't know if anyone makes such a consumer grade device.
  • michaelkenward's avatar
    michaelkenward
    There's a lot going on there, most of it hard to follow. (Heaven only know how "AVs", whatever they are, have been bugging you to update my Router FW.) But I did spot this bit:
    StagByTriumph wrote:
    .... I have had two DDoS attacks in the past 6 months
    I hope you aren't basing that statement on the logs for your R7900. Those,logs are famously wrong at reporting those things. Don't take my word for it, just search this community.
    I can't spot anything in your message that is asking for help with your router.
    If you just came here for a rant, fine, but be warned that this community is essentially a user-to-user venue to talk about technical issues, with some input from a small band of Netgear techies.
    Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
    If you want "official" support then you should go through the right channels.
    Contact Us | Support | NETGEAR
    • StagByTriumph's avatar
      StagByTriumph
      Without the rant:
      Has any other users had the problem when using a PC running Win11 (last year I was running Windows10 with the same problem),
      Outlook would no longer send/receive emails. Send/Receive ops fail with Send/Receive Error - "cannot connect".  Also, after the upgrade the latency, measured using pings to the server went from less than 10 ms to more than 2 seconds.
      The only change is the FW as stated, nothing else.
      Ideas?  I doubt the later R7900 lettered models FW can be used.
      FWIW, the DDoS were caught and blocked by Snort on my Ubuntu PC monitoring my network .
      Here is what the router log picked up: [DoS attack: FIN Scan] attack packets in last 20 sec from ip [34.117.223.223], Friday, Apr 07,2023 10:56:56
      I cannot send a note to Tech Support I need to subscribe for a support call and pay a fee, this unit is no longer supported, and that money would be better spent on a new updated router.
        michaelkenward
        That is a Google IP address.
        This is a useful tool for reducing blood pressure and baseless paranoia.
        IPNetInfo: Retrieve IP Address Information from WHOIS servers
        As to this:
        One recent user said they had success using the "chat" facility at the boot on the support pages.
