mister2's avatar
mister2
Follower
Nov 06, 2017
nighthawk x6 ac3200 correct ssid not showing up in internet access
im trying to connect to my new nighthawk router, but the ssid printed on the router is different than what comes up in the internet access settings. the password given on the router also doesnt work....
  • JamesGL's avatar
    Nov 09, 2017
    Hi mister2,
    You can reset the router to factory default and reconfigure it
