LadyLuck719's avatar
LadyLuck719
Nighthawk X6 AC3200 Throttling when I launch COD Cold War
When I launch COD Cold War my speeds are throttled. I have reset the router, added all the ports for port fowarding and updated firmware and still the same. I test my speed before launching the game and it runs around 930, after launching the game 518. Am i missing a setting somewhere. Any help would be greatly appreciated!
  • plemans's avatar
    What modem/gateway are you using?
    Are you speedtesting while playing?
    Whats playing the game and what's speedtesting?
    • LadyLuck719's avatar
      LadyLuck719
      I have fiber. Default settings for gateway. Speedtest before starting game speeds ok speed test after they drop.
      Call of duty is through blizzard. Speedtest.net is what I am using
      • plemans's avatar
        LadyLuck719 wrote:
        I have fiber. Default settings for gateway.---what gateway? model?
        What gateway?
        Why are you speedtesting during game play?
        What device are you speedtesting on? PC? Xbox?
        What speeds do you pay for?
        What speeds do you get hardwired into the router?
        How if your console attached to the router? wired? wireless?
