Cryptodd's avatar
Cryptodd
Nighthawk X6 R7900 & AT&T MicroCell
I replaced my AT&T Router with the Netgear Nighthawk X6 R7900 and now the AT&T MicroCell which was previously working well has issues with the outbound audio.     The inbound audio to a cellphone v...
  • JamesGL's avatar
    Mar 15, 2017
    Hi Cryptodd,
    Try to check with Microcell if they need a port number to be opened in the router. Also try enabling the QoS and set the priority of microcell to high.
