Cryptodd
Mar 11, 2017Aspirant
Nighthawk X6 R7900 & AT&T MicroCell
I replaced my AT&T Router with the Netgear Nighthawk X6 R7900 and now the AT&T MicroCell which was previously working well has issues with the outbound audio. The inbound audio to a cellphone v...
- Mar 15, 2017
Hi Cryptodd,
Try to check with Microcell if they need a port number to be opened in the router. Also try enabling the QoS and set the priority of microcell to high.
TheWorstPing
Apr 02, 2017Apprentice
why to high? and not to HIGHEST? curious , are you hinting that the High priority has different values that would be of better benefit than the highest option of priority? and that somewhere in the dynamic qos settings a hidden priority tree is making the best dicision for that users issue to work best when set to high? given there is no transparency on what these prioritiy values mean and what theyre best used for when the average users comon knowledge is that highest will mean best for anything and lowest would mean something else........
Cryptodd
Apr 02, 2017Aspirant
I used Highest and High QoS settings. I settled on the High QoS setting because it did the trick and I wanted to minimize the possibility of adversely affecting other applications/traffic. If I run into issues, I can subsequently move it to Highest, however High is working fine at present.
