odeca23
May 15, 2017Aspirant
Nighthawk X6 R7900 throttling internet speeds
I just recently purchased this router and it is not hitting my regular 1gbps speeds. I tried resetting the router, I have QOS off and traffic mngt off as well. When I plug my PC directly into my modem the speeds are 950up/down. I tried a different cable and have firmware updated. Need some help. Speeds are 400up down when plugged into router. Wireless speeds are the same but my main concern is the wired connection.
thanks
Had to reset the router several times and then it finally caught the correct speeds.
thanks
