Dayhiker4k
Jul 10, 2017Tutor
Nighthawk X6 R8000 AC3200 Questions: Mode & QoS
I just listed a post: "Web-based setup shows no Internet." This post is a question about setup. I thought they might me related. (1) I see it is set up in Access Point Mode. Is AP the correct Mode ...
- Jul 16, 2017
Hi Dayhiker4k,
Access the UI of the router and go to advance settings under advanced tab. Select wireless AP then uncheck the wireless AP button.
netwrks
Jul 11, 2017Master
In Access Point mode, it's common to see No Internet, as the WAN port is not connected to the WAN, but a Base router. Can you get out to the Internet? Did you configure it in AP mode, or did it switch on its own?
EDIT: What model of Comcast device do you have?
- Dayhiker4kJul 11, 2017Tutor
Hello,
Yes, I can get to the Internet. It configured itself to Access Mode. After I left the post yesterday I did a Google search. I suspect it was because of this Comcast device. It's an Arris Touchstone TG862 Telephony Gateway. It's a cable modem with WiFi built-in and that's how I get phone service. The P/N is TG02DH7862CT.
How do I reconfigure as a router? Also, how does QoS work and do I need it for my home network? I rent out rooms in my house for extra income, so it would be nice to have additional control of my network if it's not too complicated to set up.
Thanks for the help!
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi Dayhiker4k,
- JamesGLJul 19, 2017NETGEAR Employee Retired
Hi Dayhiker4k,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
