Dayhiker4k's avatar
Jul 10, 2017
Nighthawk X6 R8000 AC3200 Questions: Mode & QoS
I just listed a post: "Web-based setup shows no Internet." This post is a question about setup. I thought they might me related. (1) I see it is set up in Access Point Mode. Is AP the correct Mode ...
  • JamesGL's avatar
    JamesGL
    Jul 16, 2017
    Hi Dayhiker4k,
    Access the UI of the router and go to advance settings under advanced tab. Select wireless AP then uncheck the wireless AP button.
