ruben_zamudio's avatar
Jun 04, 2018
Nighthawk X6 R8000 Automatically Wifi network change
Hello Community! I have some devices, that they just can not go on with the current Wifi network (e.g. 2.4ghz) in that moment you have at least another one (e.g. 5ghz). That device is compatible wi...
  • Blanca_O's avatar
    Jun 10, 2018
    Hi ruben_zamudio,
    We’d greatly appreciate hearing your feedback letting us know if the information IrvSp provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
    Blanca
    Community Team
