RichardNotDick's avatar
May 10, 2023
Nighthawk X6 R8000 blocking
I found pinpointed the problem but I don't know how to fix it.
My router is blocking apps and sites, specifically my Stamps app and Word and OneDrive by MS AutoDesk Fusion360.
These programs will work for a time but then stop and not allow sight in.  Once I change the channel it will work again for a time and then block the site.
I have no blocked sites or child restrictions and such.  I have just 2 channels, 2.4 and 5.0.  I have tried to reset the router etc.  Trouble shooting with Stamps I was able to login with a mobil hotspot which then let me to cycling the channels of my router.
Reinstalled Windows 11 also but no help.
Also I have disabled McAfee Firewall and anti virus and checked Windows defender.
Can anyone help.  I may need to buy a new router?
Richard
  • michaelkenward's avatar
    michaelkenward
    What makes you think this is a router issue? That error looks more like something in Windows than a router error.
    What firmware version do you have on the R8000 device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    • RichardNotDick's avatar
      RichardNotDick
      Thank you,
      Very good suggestions, I will try to clarify my trouble shooting.
      I am using 3/30/22 - Firmware update 1.0.4.84 for R8000  verified with app version 2.26.0.2884 on my Android phone
      I think it is a router issue as I was directed by Stamps support to use a Mobil hotspot on my phone and the program worked fine, so Stamps support pass it on and said, not our problem.
      I am using Windows 11 Home Version 22H2 64 bit on an 11th Gen Intel processor.
      Authentication settings are set to Off, no metered connections, Automatic IP assignment, I have no VPN and turned off 'Allow VPN over metered networks and while roaming, Windows Firewall and network protection is turned off at this time.
      The setting in Windows to block potentially unwanted app downloads is turned off at this time.  Secure boot is on.
      I'm drawing at straws here trying to figure this out.
      I have Xfinity and modem that is located about 600 hundred feet from the NightHawk router.  (My home is this distance from the street and Xfinity wanted 50,000.00 USD to bring the router and modem to my home, I'M NOT KIDDING) so I use a pair of extenders in a Cat 6E burial cable and get a pretty consistent 75Mbps on the 5G channel down from the 100 or so I get from the street.
      So for years it has worked with the NightHawk setup just like this.  I have had a couple times I replaced it after lightning strikes etc but generally it has work in this setup.
      I am not a network expert and really don't have any more ideas on what to do to fix it.
      Thanks again,
      Richard
        michaelkenward
        Is the network set to Public or Private?
        We still don't know what that modem is.
        You seem to be on the edge of what you can get with LAN technology. Atypical networks like that are hard to diagnose.
