ren1pa
Apr 23, 2017Aspirant
Nighthawk x6 r8000 connection issues. Unable to connect directly to Arris 6190 modem
I am unable to go directly from Arris 6190 to the Nighthawk mentioned above. My last resort was to use a previous Netgear WNDR 4000 Router as a "pass through"/access point. Works ok this way, but why...
- Apr 27, 2017
The R8000 should connect and work well and get ISP speeds to spec if your testing with a wired LAN cable PC for speed testing only. QoS should be disabled on the R8000.
Then again, there maybe either a problem with the R8000 or the SB6190 or between the two. Again the 6190 modem has issues. You maybe better served by setting into a SB6183 which works well with my R7800 or a NetGear CM600. Stay away from the NG CM700 as it suffers the same issues as the 6190 modem.
You might take your R8000 to a friend, nieghbor or family member and test it out there at a different location to see if the problem follows or not. Then you'll know.
ren1pa
Apr 27, 2017Aspirant
Nighthawk X6 AC3200 R8000 Connection Issues. I am Unable to connect directly to my new Arris 6190 modem. I followed the suggestions offered, but with no improvement. (New CAT 6 cables and reset both modem and router.)
As I and the family were in need of broadband connection, I reinstalled the Netgear N750/WNDR4000, which worked well, but with dated speed performance. I searched the internet for a solution with no success.
At one point, as I had tired of connecting and reconnecting cables, I connected the Nighthawk to one of the WNDR 4000 ethernet sockets. To my surprise, I was now getting full advantage of my Comcast 200 Mbps plan.
This is "fine", I guess, but am still scratching my head as to why I cannot connect directly without using the N750/WNDR 4000.
I am thinking of buying a used Netgear modem just to see if using a Netgear to Netgear product may solve the problem.
Anyone else have any other thoughts?
I thank you and all others who have offered help. If I ever figure out this puzzle, I will definitely share.
ren
Apr 27, 2017Guru - Experienced User
- ren1paMay 02, 2017Aspirant
Thank you all, especially FURRYNUTZ, for suggesting problems with the 6190, and possible failure of the R8000.
I swapped the 6120 for the Netgear CM1000 modem and after a long time on the chat line with a tech named Preeti, it was determined that I also had a faulty Nighthawk router. I replaced this with a less expensive R7000, (Shelf Price at WM only $134, WM online$179, BB $159).
Networking using my ASUS G53S, and Network adapter,A6200 now connect me to CC at 212 + Mbps.
ren1pa
- FURRYe38May 02, 2017Guru - Experienced User
Glad it's all working now. Enjoy. :smileywink:
