appalachian's avatar
appalachian
Follower
Oct 09, 2023
Nighthawk X6 R8000 firmware update
I'm having some connection and delayed issues loading pages on my macbook pro. Do you have to update the firmware annually in order for the nighthawk to run correctly? I'm assuming this is the issue.
The bad thing is that when I go to update the firmware I don't remember my username/password. And it's saying my security answers are wrong, but I know they're not. Tried upper and lowercase too.
Thanks!
1 Reply
  • FURRYe38's avatar
    Lets check a few things first before updating FW. New FW may not fix what your having problems with.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    You'll need to factory reset the router and walk thru the setup wizard again and input your security questions correctly. Be sure to write this information down for safe keeping.
