Dayhiker4k
Apr 09, 2017Tutor
Nighthawk X6 R8000 router installation trouble
Nighthawk X6 R8000 router installation trouble. I am installing for the first time. It looks like I can connect to the Internet (although these days who knows- am getting older- having age issues), b...
- Apr 13, 2017
Ah, the "cannot connect" to router issue. That's a long running saga here.
If you cannot login to your router | Answer | NETGEAR Support
As I already suggested.
If your engineering skills are up to it, then use ipconfig to work out the IP address of your router and then plug that into your browser.
It is also worth looking at the instructions for assembling a network with a router and a modem. You have to start them in the right order. As Netgear says:
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
The Quick Start guide explains this.
You can read about firmware updates in the manual that I linked to. See page 133.
I did some work in Fortran years ago, punched cards and stuff, before I realised that I was never going to be a research scientist and moved into writing about it, and engineering.
michaelkenward
Apr 09, 2017Guru - Experienced User
The R8000 is a router. So it has to connect to the Internet through a modem.
Plug the output from that into the INTERNET socket of your router.
The Quick Start guide explains how to set things up. Find it here:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
- Dayhiker4kApr 13, 2017Tutor
Hello Michael Kenwood,
I have trouble these days with a lot of things, but I do know how to connect the Netgear router to my Comcast cable modem (It's actually called a Wireless Gateway. I use it for phone service as well as Internet, but I plan to buy a regular modem in the near future.) I did major in electronics engineering in another life, but not computer hardware, or software engineering or Information Technology. (Unless you want to count programming very early Intel microprocessors and associated "chips", and BASIC, FORTRAN, PASCAL & C programming.) I was a Test Engineer and all around troubleshooter. However, these days I couldn't troubleshoot anything due to a number of disabilities.
That is why I need some help with this router. I bought it at Best Buy on 8/9/2016, but just got around to trying to set it up less than a week ago. So...I cannot contact NETGEAR for support unless I want to pay for it. I bought an extended service plan through Best Buy/ Geek Squad. Maybe they can help me. It's working now, but I cannot access it through a browser to check out the settings and possibly change them. Something needs to be reset from the previous router setup. I found the IP Address by running Advanced IP Scanner Version 2.4, but when I went to that address with Google Chrome.
I hadn't planned to write a thesis, but hopefully I gave more helpful onformation.
