Pascal348
Jun 12, 2016Aspirant
Nighthawk X6 R8000 web browser indicates no internet
My Router is working perfectly, but, when I access the router by web browser and click BASIC>BASE, the square of internet indicates that internet is not connected. But, it is not true, because is con...
- Jan 04, 2017
Dear Friend!
I agree with you. It is a kind of bug! My problem WAS the same. I didn't do anything and one day the "Internet" appeared as "connected". So, the solution is waiting that the router will fix itself!
Pascal348
No, I am not using as Access Point. I am using as router. The strange thing that the Netgear Genie installed at the Windows 10 shows the internet as "good "! But, I can't understand what it is happening at the Netgear web brownser. Why does it indicate the internet is not connect?
TheEther
Jun 12, 2016Guru
The router is probably running some kind of test (such as pinging a specific IP address) that is failing. If you click on the red Internet square, this should take you to the Internet Setup screen. Does anything look unusual?
If you go to ADVANCED > Administration > Logs do you see any error messages?
- Pascal348Jun 13, 2016Aspirant
I didn´t find anything at the internet screen. For me is ok. And also there are not error messages at the logs. The internet led is blinking white. Is it normal?
