Pascal348
Jun 12, 2016Aspirant
Nighthawk X6 R8000 web browser indicates no internet
My Router is working perfectly, but, when I access the router by web browser and click BASIC>BASE, the square of internet indicates that internet is not connected. But, it is not true, because is con...
- Jan 04, 2017
Dear Friend!
I agree with you. It is a kind of bug! My problem WAS the same. I didn't do anything and one day the "Internet" appeared as "connected". So, the solution is waiting that the router will fix itself!
Pascal348
Jun 20, 2016Aspirant
if someone have another suggestion to solve the problem, please tell me.
- JamesGLJun 22, 2016NETGEAR Employee Retired
Hi Pascla348,
1. Please try using a different web browser.
2. Reset the router or reload the firmware.
JamesGL
Community Team
- Pascal348Jul 02, 2016Aspirant
1) I used the browser of my IPAD (safari) and I can see the same problem
2) I loaded the update of the firmare and no changes.
- JamesGLJun 26, 2016NETGEAR Employee Retired
Hi Pascla348,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
