Pascal348
Jun 12, 2016Aspirant
Nighthawk X6 R8000 web browser indicates no internet
My Router is working perfectly, but, when I access the router by web browser and click BASIC>BASE, the square of internet indicates that internet is not connected. But, it is not true, because is con...
- Jan 04, 2017
Dear Friend!
I agree with you. It is a kind of bug! My problem WAS the same. I didn't do anything and one day the "Internet" appeared as "connected". So, the solution is waiting that the router will fix itself!
jimmyandrews
Sep 11, 2016Aspirant
Same here.
NOT in AP Mode.
Modem hooked into Internet Port.
Internet is DHCP.
Basic Overview shows not connected to the internet, Advanced tells a different story. However, this isn't the first Netgear router that I've had this issue with. It has happened with every one I can remember when Netgear switched to the current GUI. I always assumed it was some kind of bug that they'd eventually fix. For me, it is 100% cosmetic, but would hope they'd get it fixed. Maybe related to my modem, a Motorola SB6120?
- Pascal348Jan 04, 2017Aspirant
Dear Friend!
