Pascal348
Jun 12, 2016Aspirant
Nighthawk X6 R8000 web browser indicates no internet
My Router is working perfectly, but, when I access the router by web browser and click BASIC>BASE, the square of internet indicates that internet is not connected. But, it is not true, because is con...
- Jan 04, 2017
Dear Friend!
I agree with you. It is a kind of bug! My problem WAS the same. I didn't do anything and one day the "Internet" appeared as "connected". So, the solution is waiting that the router will fix itself!
krebbs777
Jan 04, 2017Aspirant
So... I don't know if our issues are fully related, but I thought I should post this since I never found any mention of it anywhere in my research of the web.
I've been reading up on multiple forums about the R8000 that I own. I recently went to the separate modem and router after my combo unit wasn't cutting it as far as signal strength. I have had nothing but problems with the R8000 as far as staying connected to the internet. At first I thought it was my ZyXEL C1100Z modem having the issues, even though both the modem and R8000 router showed no signs of any problems (internet light is white on router, everything good in Netgear Genie). I took the route of blaming the much cheaper piece of equipment. I would power down the modem and then power back on. It helped... for about a 3 minute window after internet connection was established. Then I would lose internet again for a few minutes. Then back on. Both modem and router never showed any signs of problems. I would have internet for hours, sometimes all day. But then out of nowhere, no internet until I powered down and restarted. I also had problems with using more than 1 device at a time - especially if streaming Netflix on the TV.
Yesterday when I lost internet through wifi, I connected the ethernet cable from the modem directly to my computer. I had internet! Connected the cable back to the modem and had wifi internet for 3 minutes, then nothing. I went through hours of troubleshooting and web research (on my cellular iPad) and found nothing that would help. I factory reset everything and set everything back up to where I had it. Not fun when I had to reconnect many of my other devices throughout my home again as well! (Sonos, Nexia Home Intelligence, Philips Hue, etc.). Maybe unrelated, but I also noticed our video baby monitor (wireless, but not through our wifi) would cut out at random times, but also when messing with router settings. Nothing I had spent hours doing had helped.
I always had one thing in the back of my mind that didn't add up: Why would streaming Netflix ruin the chance of any other device getting an internet connection faster than a 14.4k modem? This problem was non existent with my previous modem/router combo...
My final experiment (with that previous thought in mind) was to turn off the Implicit Beamforming on the modem. That was this morning and it's been 5 hours since then. Maybe I'm just randomly catching one of those good stretches. However, I'm streaming HD Netflix on the TV, my wife is browsing the web on her wifi iPad, I'm browsing my news feed on facebook (which autoplays video when connected to wifi) using my iPhone and browsing the web on my computer. All is perfect now, or as perfect as my blazing hot 6 Mbps connection out in the country gets! Any ideas of why implicit beamforming hurt my situation???
I hope this may help some others experiencing similar problems!
TheEther
Jan 05, 2017Guru
Netflix can consume up to 6 Mbps, leaving nothing for the rest of your devices, so I'm not sure that beamforming is to blame. But I also am not discounting the possibility of a bug with beamforming. Perhaps you can try turning it back on and run a speed test. If you see a clear difference with and without beamforming, then use whatever works!
- krebbs777Jan 06, 2017Aspirant
Yes- Netflix will consume a good chunk of 6Mbps, but before I made the switch to the R8000 I was still easily able to run multiple wireless devices while streaming Netflix (I was running this wireless setup for years - only the range of the wifi signal made me change to a separate router). It seemed strange that once I made the jump to separate modem and R8000 router, my wifi connection was all to one device and nothing else.... Or nothing at all! When it worked, it worked well for one device. Extremely frustrating with all the wifi "brownouts" throughout the day! I will try turning beamforming back on at some point, but for now I've had good internet on all devices since Wednesday and I'm going to ride that train for a bit yet! :smileyvery-happy:
I will update when I turn on beamforming again...
