Seventhwinds
Apr 15, 2018Aspirant
Nighthawk X6 R8000 with load balancer?
Hello there, I have two different load balancers that are not in use in my home however I plan on picking up a second Internet connection so that I can make use of the load balancing to evenly distri...
- Apr 16, 2018
I think I got my set up working with my TP-link 470T+
DCHP 192.168.1.1 on the TP
DCHP 192.168.1.2 on the netgear
Internet is run through the TP, and then sent to the netgear via lan cable and doing so allows my QOS settings to work which is what I wanted however the speed test won't work because it does not detect the wan so I'll just input that manually.
Now I just need that second connection here ugh July 5th is the install date....
Seventhwinds
okay, any suggestions to a netgear dual wan for load balancing that's not eol?
schumaku
Apr 15, 2018Guru - Experienced User
Gee, I would have made you a Netgear proposal of course. Some leading edge for xDSL bonding is available ie. from Viprinet
- SeventhwindsApr 15, 2018Aspirant
That's pretty neat but I just need balancing, bonding might be a bit expensive.
What's the netgear solution you had? I'd love to stick with netgear - William10aApr 16, 2018Master
I have seen videos on youtube where people have use load a balancer with two or more isps and a single network from what I undersatnd their reasoning for doing it is like you said to sperate the band witdh load over multi isp's and they said they have a back isp connection if for some reason one goes down sounds like a good idea. Have not tryed it myself.
- schumakuApr 16, 2018Guru - Experienced User
Seventhwinds wrote:That's pretty neat but I just need balancing, bonding might be a bit expensive.
True bonding ie. of multiple DSL would require support by the ISP anyway. Even if you write "just balancing" - it's not as simple as it appears. Was overseas not so long ago, and massively struggled with accessing the Internet (Web applications), establish a VPN, from a hotel. Discovered that their balancing sent out the packets on random network connections, and (of course) my as well as several popular application firewalls denied and blocked the sessions, because the source IP changed randomly - for the very same TCP session, for the same UDP spource and destinaiton port.
- SeventhwindsApr 16, 2018Aspirant
