Seventhwinds
Apr 14, 2018Aspirant
Nighthawk X6 R8000 with load balancer?
Hello there, I have two different load balancers that are not in use in my home however I plan on picking up a second Internet connection so that I can make use of the load balancing to evenly distri...
- Apr 16, 2018
I think I got my set up working with my TP-link 470T+
DCHP 192.168.1.1 on the TP
DCHP 192.168.1.2 on the netgear
Internet is run through the TP, and then sent to the netgear via lan cable and doing so allows my QOS settings to work which is what I wanted however the speed test won't work because it does not detect the wan so I'll just input that manually.
Now I just need that second connection here ugh July 5th is the install date....
schumaku
Apr 16, 2018Guru - Experienced User
Seventhwinds wrote:That's pretty neat but I just need balancing, bonding might be a bit expensive.
True bonding ie. of multiple DSL would require support by the ISP anyway. Even if you write "just balancing" - it's not as simple as it appears. Was overseas not so long ago, and massively struggled with accessing the Internet (Web applications), establish a VPN, from a hotel. Discovered that their balancing sent out the packets on random network connections, and (of course) my as well as several popular application firewalls denied and blocked the sessions, because the source IP changed randomly - for the very same TCP session, for the same UDP spource and destinaiton port.
Seventhwinds
Apr 16, 2018Aspirant
