rameshav's avatar
rameshav
Follower
Oct 28, 2021
Nighthawk X6 R8000
Firmware: v1.0.4.76
Model - R8000
I see that my router is only allowing 16 devices at the max, in both 2.4GHZ gn 5GHZ, together(Combined). Any additional devices, router is saying, no internet.
1 Reply
  • plemans's avatar
    A little more info about your system is needed.
    1. what modem/gateway do you have?
    2. when did this start?
    3. have you tried a simple factory reset and reinstall (don't use a backup to install)?
