trusyty's avatar
trusyty
Follower
Feb 17, 2018
Nighthawk X6 router speed testing at 120mb/s when modem is testing 400+mb/s
We are in LA and have Spectrum internet with over 400mb/s speeds (tested and confirmed from modem). We just had an installer out that re-wired for the newer internet. Now, just days later, we are getting 120mb/s tops out of the router with confirmed 400+mb/s from the modem with speed tests (directly connected).
Any ideas on how to play with the router settings to get better results? My room is right next to the router (less than 8 feet) and I still only get 120mb/s from the router.
Thanks ahead of time!
  • Hi trusyty,
    What is the firmware version of the router? Make sure to update it.
    Disable QoS.
    Reset and reconfigure.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi trusyty,
    Disable QoS.
    • JamesGL's avatar
      JamesGL
      Hi trusyty,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
