gmsaylor
Jan 19, 2018Follower
Nighthawk x6s AC3000 compare to Nighthawk x8 AC5000
I am trying to decide which of these two routers are superior technically. They seem almost identical except the x6s says it has 6, external, high performance, amplified antennae, and the x8 says it...
- Jan 20, 2018
The x6s and the x8s are both good routers the x6s like you said will give you a faster network connection too a computer or nas device as long they can access both network cables to enable it unlike the x8s which uses a external hard drive to store information via a usb connection, the x6s would be a better choice if storage is important to you.
Dlna is for movie and video steaming then the x8s may fit better if that's what you are into.
Either would do in must cases all depends on what you want to do.
William10a
Jan 20, 2018Master
mreg376
Jan 21, 2018Guide
If I were you I'd take a look at the X4S/R7800. Probably has the best range (in terms of distance AND reliability) of all the current Netgear routers, also about $200. It's similar in hardware to the Synology RT2600ac, also en excellent option. I've used both -- great range, stable.
