ja95606
Jan 19, 2018Guide
Nighthawk X6S AC4000 R8000P-Lose internet connection every other day
From November 16, 2017 until today (Jan. 19, 2018) my Netgear router, model R8000P Nighthawk X6S Tri-band has lose internet connection every other day. To get it back I have to unplug the router, plu...
- Jan 28, 2018
Just an update on my lose internet connection isssues; as of Friday Jan 26, the Dlink router hasn't lost any connection at all. I've disabled the Dlink router, enabled the Netgear X6S R8000P router back in service, downgraded a previous version of the fimrware, and as of Friday afternoon (Jan 26) until the present Sunday Jan 28 at 12:30 AM, the Netgear hasn't lose connection either. The following gives instructions on how to download, the new firmware to your router. Do not upgrade using a wireless connection. Go to Netgear Support page; sign in; click on Download; enter he Product name or model number; Next page, right side Firmware/software; click on the down arrow "v"; and look for firmware V1.1.4.6
This is the version that's working for my router right now,wihout losing internet connections. Aslo keep in mind, this is for the Netgear X6S AC4000 model R8000P router.
Zantetsukin
Jul 21, 2018Tutor
Just got mine yesterday. Hooked up, updated, noticed two things. Immediate boost to my wifi range from their older ac1900 models which is great, the second thing is the problem. It too drops connection of networked devices be they wired or wireless. For mine it seems to do it initially upon usage. As in, if I open a web browser, any web browser, and enter something to search, the first result is an error (failure to connect, no internet, not found etc....). I have to refresh tbe page, sometimes repeatedly, before it connects. It is the same for any applications that require some form of internet service, on an th device. Try playing a game on ps4 for example, first it will fail to connect to the servers, then sometimes it will connect, eventually. Many games wont even boot all the way without that connection though... so....
While running the speed test built into the router comes back fine, running it from aPC, a phone, a console or tv or any other device will result first in straight failure to connect, then some other failure, eventually it will connect only to show a failure in upload and download speeds.....
It seems odd tk me that it doesn't want to shake hands and reluctantly does so only after trying several times.. I have to do this anytime I want to play a game, watch tv, surf the net. And trying to fill out forms online is a nightmare as reloading a security page often is finicky and results in having to start all over again......
YungSynthlord
Jul 22, 2018Aspirant
Make sure you update the firmware. Theres a new firmware update. When you update you have to be hardwired to your router. The new update should fix your connection issue.
- ZantetsukinJul 22, 2018TutorIt is the latest, and did not resolve the issue, so I got rid of the issue all together and replaced it with another router, which works great, as it should. I honestly can't believe you are willing to sell defective products, and in the nearly 10 months it has been out you haven't fixed it.......
Thanks for not helping, and being useless.- ZantetsukinJul 22, 2018TutorFyi, that second half was directed at Netgear, not you. Good luck!
- myerswJul 22, 2018Master
Not sure what you are smoking/drinking. How many here is a new firmware to fix connection issues have been issued so far? Would not hold out hope for a fix other then replace with some totally different router or even brand.
- YungSynthlordJul 22, 2018AspirantI don’t smoke anything and don’t understand why that’s necessary. There was one firmware release that I saw that fixed the issue which was the 1.1.4.0 that I mentioned a couple days ago. I updated it and have had no issues with connectivity. So just because YOU had a problem and hate the device does not mean that an actual work-around and a fix by Netgear actually happened. So enjoy that hatred hope it makes you feel better.
For anyone else looking for a fix they have fixed the issue just make sure you update the firmware to the newest update while you’re hardwired to the device.- jikamensJul 23, 2018Apprentice
YungSynthlord, if you read https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Beta-Firmware-for-R8000P-only-if-you-have-these-issues/td-p/1538164/page/10 (and the previous nine pages in that thread), you will see that Netgear has released many new firmware releases which they claimed would fix the problem of the R8000P needing to be rebooted regularly, and all of them, including the most recent firmware release, have failed to solve the problem for many people.
So while you may be lucky enough that one of the firmware releases fixed the problem for you, many other people have not been so lucky, and claiming that the problem has been fixed for everyone is simply not true. I'm glad the router is working for you, but please don't assume that just because it's working for you, it will work for others as well. There is ample evidence to the contrary.
Furthermore, the firmware version number you mentioned in your most recent comment, "1.1.4.0", does not exist. The most recent firmware release is 1.4.1.24.
