phwinmd's avatar
phwinmd
Follower
Sep 28, 2023
Nighthawk X6S R8000P Guest Network won’t enable with password protection
I am setting up a Nighthawk R8000P and have my main networks broadcasting and when O go to enable my guest network, if I password enable it, the router sends an error below. If I just open a guest network without a password, it works great. Any kind of password encryption, the below error: “Configuration Error”
Any ideas???
1 Reply
    Any ideas???
    Recommend you close the mobile application.  With a real computer connected to the router via Ethernet cable, use a web browser to log in to the user interface for configuration.
