Ahmed_225's avatar
Ahmed_225
Nighthawk X6S SSID Broadcast Not Showing Up
I tried to do everything by resetting my router, changing my power adapter, downgraded and upgraded the firmware I even have checked mark the SSID so many times. However, my router doesn't show the wifi. And there is an acclamation mark that seems like there is something wrong with the WiFi.
  • plemans's avatar
    did you push and hold the wifi on/off button on the router? It needs to be held for 2 seconds
      • plemans's avatar
        Not a good sign if the wifi on/off button doesn't work and neither does a factory reset.
        Is it still in warranty?
