TheWeasel's avatar
May 14, 2024
Nighthawk X8 AC5000 replacement
I currently have a Netgear Nighthawk X8 AC5000 running in Bridge Mode.
The unit is starting to fail and I would like to purchase a replacement.
Other than searching through the spec sheets of every router, is there a list of available models that are capable of running in Bridge Mode?
I emailed Sales, but have yet to receive any response.
    • TheWeasel's avatar
      TheWeasel
      Tutor
      Thanks.
      I'd looked through some of those but found most were able to "Set up a bridge for a port group or VLAN tag group".
      Yes, I was looking for a wireless bridge mode : client to bridge via ethernet, bridge to router via wireless.
      • FURRYe38's avatar
        The ones listed in the applies to should have the wirleess bridge mode feature as well.
