TheWeasel
May 14, 2024Tutor
Nighthawk X8 AC5000 replacement
I currently have a Netgear Nighthawk X8 AC5000 running in Bridge Mode. The unit is starting to fail and I would like to purchase a replacement. Other than searching through the spec sheets of every...
May 14, 2024Guru - Experienced User
The ones listed in the applies to should have the wirleess bridge mode feature as well.
TheWeasel
May 14, 2024Tutor
I wish that were true. But only one that I found while randomly searching (RAX30) mentioned "Enable bridge mode" - the wireless bridge I need.
- FURRYe38May 14, 2024Guru - Experienced User
Enable Bridge Mode maybe referring to wireless bridge mode. All the models listed should support the wireless bridge mode feature.
- TheWeaselMay 14, 2024Tutor
That's what's confusing.
All the ones I've looked at mention "Set up a bridge for a port group or VLAN tag group", but only a few also have a section on "Enable bridge mode". They're listed as two different features. I don't want to buy one that doesn't have what I need. I guess I'll have to spend the time to search through all of them, note the ones that have "Enable bridge mode" and then check those for price and other features.
Thanks for your time.
I know my RAX120v2 and RAXE500 has it. I'd have to check my RAX50v2, been a while since I had it online.
Find you a good retailer on line with a good refund policy. I get stuff from Amazon all the time. Good on returns.Good Luck.
