TheWeasel
May 14, 2024Tutor
Nighthawk X8 AC5000 replacement
I currently have a Netgear Nighthawk X8 AC5000 running in Bridge Mode. The unit is starting to fail and I would like to purchase a replacement. Other than searching through the spec sheets of every...
May 14, 2024Guru - Experienced User
I remember I had a RAX70 for a short time. That had bridge mode as I was trying to test with a CAX80 back then.
TheWeasel
May 14, 2024Tutor
This probably won’t be of any use (except to me), but here are the models under the AX WiFi 6 heading that include the Wireless Bridge feature:
RAX120 , RAX120v2 , RAX30 , RAX70 , RAX75 , RAX78 , RAX80
- FURRYe38May 14, 2024Guru - Experienced User
I'll see if I can get NG to update that linked model list.
