Danni-Boi
Jun 27, 2016Aspirant
Nighthawk X8 R8500 Genie support?
Greetings. I Already find the solution (if it can be call as so) of this subject right here. Very informative awnser towards this shared problem. My only question would be, when this type of rout...
- Aug 02, 2016
OMG GUYS! FINALLY DID IT!!!!!!
My netgear wifi was giving me issue and not connecting to the 5ghz. And I had to restart my pc and or disabling the connection so it could connect withouht issue.
I did the hardcore reset. (as one of you guys mention)
This was my step.
1. Turn off everything and disconnect everything entirely, and connected again with the cables.
2. Turn the Arris modem and reset it.
3.Turn off the Netgear and reset.
4. Turn the Netgear and reset it again.
5. Connect the yellow cable to the main modem
6. Wiat for everything to boot up and issue solve
Guys thank you SO much for all the help, even though it did took me a lot to figuer it out and or understand this issue. Thanks for the advices and the ideas, they help me also to understand a bit.
I din't have to do nothing inside the Arris gateway. Now I can acess the gateway of my netgear. And din't think with logic, I just wne bananas and disconnect and did the hardcore reset. Now I will go and watch a guide to set up everything on my netgear from the gateway.
P.s. Finally! honestly thanks, thanks. I'm happy.
Danni-Boi
Jul 07, 2016Aspirant
Bealive me.
I have done the ipconfig to verify the IP address of my router using the cmd. That is why, my last resort was login in here :/
The thing is this, I have my router connected with the modem. If that does something against me not being able to access the gateway when I try to?
Even though when my modem is turn off?
VE6CGX
Jul 07, 2016Master
In real world some times somethings are beyond logic. Just disconnect everything as I suggested. BTW, is that modem is combination mode/router? And when you reset the router does reboot and comes up ready? Is the router functioning normal other being unable to
log in? If you ping the router does it respond normally? If so, what is the TTL value?
