d0x
Jan 20, 2022Guide
Nighthawk xr1000 Duma errors (multiple)
I just bought an XR1000 yesterday and I was setting it up and after I was done and the firmware was updated I started getting some errors and I was also unable to enable upnp which was disabled by default.
I'm on firmware 1.0.0.58
An example of an issue I'm having is besides upnp is when I click certain pages in the settings an overlay will pop up with some random looking error and the page itself won't work.
this is one of those times that you'll get better help posting in the proper foum.
You're in the standard router forum versus the pro-gaming one that runs dumaOS.
The guys on there are super active and involved. I'd start there.
- d0xGuideI figured. I tried to post there but when I typed my model# it couldn't find it. Then a few min ago I registered my serial# and now it shows up... Sigh
I'm actually making the new topic now.- plemansGuru - Experienced User
Hope it works well. the guys on there are great to work with and help out.
