NightHawk_mess's avatar
Feb 09, 2021
NigthHawk Firmware failure
Night hawk does firmware update and fails- no inrternet- no access to the router software via either ethernet cable, wiFi or app.
Hard reset does not work.
Power cycle does not work.
Technical support have no clue.
Unit is about 2 years old was working perfectly fine no issues until the manufacuterer decided to update the firmware.
So it is out of warrantee and unless I purchase a support 'thingy' Netgear refuses to help.
Looks like another one of these scams to make money.
1 Reply
