EFeather
Dec 28, 2020Follower
Nitehawk ac3200 R8000 - non-functional after firmware update - can't connect to it
I used my Nitehawk Netgear App on my iphone to launch the current recommented firmware update on my AC3200 R8000 Wifi Router today. The process seems to have not worked and the router now will not function. When I turn it on the following happens:
- all lights come on for a moment
- switches to power light only - in orange
- switches to power light only - in white
- power light starts blinking
This is it. I have gone through the standard connection process multiple times to clear out and power up my modem and connect the router and power it up. Same thing happens every time.
I am trying to do a manual update of the software, but I do not know how to connect to a wifi router that is non-functional. When I go to the Router Login page it tells me that my router is not connected to the wifi network - or that I must not be connect to my router's wifi network. Clearly this is correct because there currently is no wifi network.
Does anyone know how to make this fix? (I am not a very technical person, so need this in simple terms)
I would prefer not to have to go buy a new router. Hope youn can help! Thank you.
1 Reply
to start off with, I'd never recommend updating via the app. When we see corrupt firmware issues, it tends to be from people updating over the app or wireless.
Did you try a factory reset? push and hold reset for up to 30 seconds while powered on.
If that doesn't help, you might have corrupted the firmware. you can try using tftp or nmrpflash to fix.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
