ACStoudt
May 24, 2021Aspirant
Nitehawk Internet drops and Qos downstream setting
Arris SURFBoard SB6141, is connected to Netgear Nitehawk AC1750, model R6700v2.
Five devices are connected to the router via WiFi. Two Rokus, one computer, an IPhone, and a printer.
I am having intermittent internet drop outs on the Netgear, on the daily. Modem shows that internet is available. Dropouts are causing my streaming apps (YoutubeTV, Pandora) to stop working, making my computer complain, and driving my cell phone to data overages. It’s just me so there are no more than two devices using the internet at the same time. I consulted the Netgear user’s manual and thought that I would at least try to Optimize Video Streaming with Downstream QoS for my main Roku. Manual says to log in to the router and Select ADVANCED > Setup > QoS Setup > Downstream QoS. I logged into the router, via WiFi, and cannot find anywhere to tweak the Downstream QoS. I did, however, find that I can assign priorities to the devices that are connected to the WiFi. I tried several times to assign said priorities but they keep reverting back to “normal”. Meaning, I set the priority of one device to “high”, set the priority of the second device to “low”, and the first device reverts back to “normal”. Per the manual instructions I did click the Refresh button in the web browser just in case the changes were made, but the old settings were still in the web browser’s cache. For the record, I cannot find any “Apply” button that can be used when making changes.
I did update my firmware to the latest version and it has not helped.
Therefore, I have a two problems. One, how do I stop the Netgear from losing internet connection? Two, how do I increase the Downstream QoS for my streaming devices?
What firmware version do you have on the R6700v2?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
How fast is your Internet service? Anything much higher than 200 Mbps and QoS just slows things down. What makes you think that you need it?
- ACStoudtAspirant
Router Firmware Version V1.2.0.76_1.0.1
Xfinity/Comcast Blast. Up to 200Mbps download. Up to 10 Mbps upload.
I just thought that increasing the Download Qos for my streaming device (Roku) would stop the death spiral of buffering (when the internet is working)
You have the latest firmware.
That is way faster than you need for streaming and for most normal activities.
What happens when the only thing happening is the streaming?
How is all this stuff connected? Wifi? Wired is always faster.
From that bit it seems that you are trying to configure your device using a mobile app. Not a good idea. As you have discovered, something are not possible on the app, including QoS tweaks. The apps are for simple stuff. Anyone with a bit of knowledge soon abandons that way in.
The fact that you lose the Internet from time to time suggests that you might like to do a bit of troubleshooting before worrying about QoS.
