LangWith's avatar
LangWith
Follower
Jun 22, 2021
no confirm button to initiate firmware upgrade
Hello,   In an effort to update the firmware (1.0.0.60), which I have done on this computer before using Safari, I cannot see a button to allow me to confirm that I would like to do the update to v...
  • antinode's avatar
    Jun 22, 2021
    > Why is the confirm button not showing to allow the update to be done
    > in the assistant?
       Fine quality firmware development and testing?
    > If I have to do this manually, is the higher version (1.0.0.104)
    > suitable considering that it is not the one offered when using the
    > assistant?
       If you're in doubt, then look for "View Previous Versions" under the
    latest available version on that page.
       Complaints abound about failure to suggest multiple newer versions on
    the R7000.  One example:
          https://community.netgear.com/t5/x/x/m-p/2069376#M186506
    Similar problems on other models would not amaze me.
          https://community.netgear.com/t5/x/x/m-p/2107477
