Aljeko
Feb 24, 2018Aspirant
No internet conection on wifi after v1.0.0.122 update
Hi,
Never had an issue before with the R7500, but after the v1.0.0.122 update I have no internet conection on wireless 2.4 or 5 Ghz devices connected to the router(Android and iOS). Wirerd devices work fine.
I have mad a factory reset and it was ok for 2 days then te problem came back.
Thanks
Alex
Hi,
Problem solved :-)
I discoverd that my extender needed a firmware uppdate and after I did that I got internet conection back on my wifi devices.
/Alex
- JamesGLNETGEAR Employee Retired
Hi Aljeko,
Try changing the channels of your wireless network.
Hi Aljeko,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- AljekoAspirant
Hi,
Problem solved :-)
/Alex
