wernd
Apr 06, 2020Tutor
No Internet connection after factory reset
I had been having issues with my internet connection and wasn't sure if it was my router or ISP mode. My ISP replaced my router. in the meantime i reset my Nighthawk to Factory. Now when i plug the WAN from my modem to the Nighthawk, there is a red light for the WAN/Internet. I have done the reboots, etc. Nothing but a red light on the Nighthawk. Called the ISP and everything is working perfectly. Help and advice
Dennis
the windstream T3200 has an integrated router. try switching the netgear to AP mode. (access point). That why you only have device acting as router on your network.
What isp modem are you using?
firmware on the nighthawk?
- werndTutor
Windstream T3200
Nighthawk X6S. Firmware was updated by me about 3 weeks ago. I can't get on the GUI to see it right now.
 - werndTutor
