Jay924
Jun 22, 2019Tutor
No internet on R8500 when pc connected to CM1200
Hello all, I recently purchased a CM1200 modem and R8500 router in order to upgrade to Gigablast by Cox. Currently testing setup and it works flawlessly as long as my pc is hardwired to the R850...
- Jun 22, 2019
Many cable ISP allow only one device only issue one IPv4 address to one MAC address - sometimes the cable modems require a restart before other sysems can access the netwrok again. So either a PC, or the router.
antinode
Jul 02, 2019Guru
> [...] another post on the CM1200. [...]
Thanks for the helpful link?
> [...] what switch would you recommend?
Generally, for eight ports or fewer, I lean toward the cheapest piece
of (gigabit) Chinese junk I can find at the local MicroCenter store on
any given day. If I'm in an extravagant mood, I might splurge on a unit
with a metal case. (Slightly less likely to get pulled off the shelf by
its cables.)
