OorTael5
Feb 11, 2017Aspirant
No Internet with R7800 and Arris TG862 Modem
I'm trying to install a new Nighthawk AC2600 R7800 router with my existing Arris TG862 from Time Warner. When I try to follow the installation instructions I can connect to the router's wifi but the...
- Feb 11, 2017
I assume you've tried testing your cables by using each one individually connected between your computer and the modem ensuring they all give you an internet connection.
Try using your computers MAC address in the modem. Connect the computer up to the router and log into the routers web interface. In the Basic tab select Internet. Scroll down the page and under Router MAC Address select Use Computer MAC Address. Click Apply at the top of the page. Test out the router. If it didn't work try powering the router off then on.
LeeH
Feb 11, 2017Prodigy
William10a
Feb 11, 2017Master
If a windows computer in the lower left corner you see a box for lan or a wifi symbol with yellow triangle on your screen on the task bar along the buttom of the screen or close depending on windows version and browser.
I use the same modem a hateful modem but have phone service with them and have to use.
Here is the way I fix my Internet connection problem I lose power
1 unplug the modem(remember to remove the battery as well) and router
2 let sit for a minute or two
3 plug modem back in(remember to put battery back)
4 wait for modem lock in
5 plug in router and wait for it to lock
6 turn on a computer and check to see if you have the Internet now
I hope this helps
