orbeavhawk's avatar
orbeavhawk
No Longer able to access my Router Software?
Please advise - now when I enter www.modemrouter.net in URL - it sends me to some NNetgear Page/site and does nof
give me access to software for my router, is there some other way?   TKS
  • plemans's avatar
    Oct 22, 2021
    Try using your default gateway address to access it
  • plemans's avatar
    Try using the ip address of the router.
    The default is 192.168.1.1
    It could have changed if you're in a double nat.
    What gateway do you have?
    • orbeavhawk's avatar
      orbeavhawk
      TKS for response!
           I used "ipconfig" to get info for you:
           IPv4 Address:   192.168.0.18
          Default Gateway:  192.168.0.1
      • plemans's avatar
