tkwilli
Jan 18, 2018Tutor
No new updates
I’ve received a couple emails over the past couple months stating a new version of firmware is available. Checking this website it does indeed show newer firmware. I show that I am running Firmware Ve...
- Jan 20, 2018
Okay, here we go - I have the results for this issue. I was originally at V1.2.0.22_1.0.78 of firmware for my Netgear Nighthawk R6900P router. I just manually downloaded the latest firmware release NETGEAR Router R6900P V1.3.0.8_1.0.93. The manual upgrade after downloading this release to my PC worked fine. What this means to me is that when the Netgear Router is operating in Access Point mode, it will appear to go to the Netgear server to check for the latest release, but apparent this function must be disabled like many other functions if your router is operating in AP mode. I am current using the Netgear router in AP mode since I have a Verizon Fios router in line from a recent upgrade to Verizon Fios Gigabit Internet. My plan is to eventually eliminate the Fios Router, since the Netgear WiFi coverage is far superior to the Verizon Router. I hope this helps those in similar situations where they have their router attached in AP mode to an ISP router. I guess I will just manually perform these upgrades while my router is operating in AP mode. It would be benefical if Netgear could make in known that the firmware check routine does not work in AP mode, as they have done with the other functions that do not work. As a previous responder mentioned, although they do not mention this by name, some of the functions that will not work in AP mode would make you think that the firmware check does not work. It is still not clear to me why it does not work since Internet access gets passed though the Netgear router in AP mode. Thank goodness for the Netgear emails or I would not have realized that my router was out-of-date because I have always used the firmware check procedure and it does appear to go out to the Netgear server to check and comes back no newer firmware available. CASE CLOSED. Thanks for all our your input. I was pleasantly surprised at the number of great, timely suggestions.
IrvSp
Jan 19, 2018Master
I just got the e-mail too... for my R7000. Thought it would be the long awaited 'fix'.
Update on router didn't find anything past the V1.0.9.18 I'm on, and neither did I find one on the SUPPORT D/L site for the R7000.
Looks like another blast to a bunch of people it doesn't pertain too????
michaelkenward
Jan 19, 2018Guru - Experienced User
Did that arrive today?
It would be typical of Netgear to blast out these things at the end of the week. Just before the official support teams go off for the weekend.
- IrvSpJan 19, 2018Master
michaelkenward wrote:Did that arrive today?
Yup. just came in at 10AM, but the SENT time was yesterday at 7:10PM.
Wouldn't be the first time they messed up, and note, it was a 'Security Update', which would have been probably wrong for at least the R7000 anyway.
- michaelkenwardJan 19, 2018Guru - Experienced User
You summed it up earlier really. They just blast these things out regardless.
I guess it makes it look like they care.
