MauckFL
Sep 25, 2021Follower
no wifi connection
I've been trying for 2 days to get wifi with this. I've had it half a year and no probs til now. I can access the internet with ether net. Ive used the Nighhawk app. No good. What else can I ...
michaelkenward
Sep 26, 2021Guru - Experienced User
What else can I try to do?
You can start be telling us what happens when you try to use the wifi.
Are the wifi LEDs on?
Can wifi clients see the SSID from the router?
Have you tried pressing the wifi on/off button on the router? The one on the top, second from the right.
