dgreen97
Dec 30, 2020Guide
None of my kindles will connect to Nighthawk router
I have the RAX50S AX5400 nighthawk and I can't get either of my kindles to connect to this thing. I've tried a number of different options with the kindle and changed the security mode on the nighthawk back and forth but no matter what I do it won't connect to the kindle oasis or standard kindle. The only way I can sometimes get it to connect is using the WPS button but most of the time that doesn't work either. How do I fix this?
Have you tried logging into it and disabling wireless AX?
Some wireless device manufacturers (like intel) had issues when AX first came out.
I'd also check to see if the kindles need updating. maybe their firmware is behind
