JOhngoes
Sep 01, 2016Aspirant
NOt able to connect to my netgear router
i have my netgear router for almost 6 months now, and it has never given the satisfaction of a good wifi coverage on the attick of my house. Wifi repeaters did not work or are expensive for dual band...
- Retired_MemberSep 01, 2016
Based on this I would suggest you set r7000 in ap mode and e3000 also in ap mode. Connect via a data cable to isp box.
Retired_Member
Sep 01, 2016log into the router and go to attached devices ......all the devices should be listed along with their IP address.....if option is available Use address reservations for it so the IP won't change when router is power cycled.
If the r7000 is connected to another router you should use AP mode
JOhngoes
Hi Searay,
how can i connect to the router when i do not know which ip adres it has? The Ip adresses i know are not responding , so probably it changed from ip adres, and now i don't know how to find it? The Netgear should be the main router since it is the most powerfull and newest router, but i cannot connect to it. So the answer on log on to the router does not fit the question. Do you have any other options?
Cheers JOhn
You said you connected the E3000 isn't that a router?
- JOhngoesSep 01, 2016Aspirant
yes the linksys is a router, but i am using it as an accesspoint. So DHCP is off and it is only used for WIFI
ok
what is the gateway IP
click on wifi connections and then details
