JOhngoes
Sep 01, 2016Aspirant
NOt able to connect to my netgear router
i have my netgear router for almost 6 months now, and it has never given the satisfaction of a good wifi coverage on the attick of my house. Wifi repeaters did not work or are expensive for dual band...
- Retired_MemberSep 01, 2016
Based on this I would suggest you set r7000 in ap mode and e3000 also in ap mode. Connect via a data cable to isp box.
JOhngoes
Isp modem/gateway make & model and what Mode is in if capable of being a router
ISP : arcadyan telfort nl experia box v8. Is capable as being router. DHCP is on ( for tv) and INTERNET. Wifi disabled. IP 192.168.2.254
R7000 what mode is in and how is it connected
R7000 DHCP on connected to the ISP as internet input to R7000. Wifi is enabled. not known which ip it has, nor can i connect to this one. i suspect it to be 192.168.2.1. N
E3000. DHCP off. Wifi on. i suspect this one to be IP 192.168.1.1
(4 Views)
Retired_Member
Sep 01, 2016Based on this I would suggest you set r7000 in ap mode and e3000 also in ap mode. Connect via a data cable to isp box.
