jhinkle's avatar
jhinkle
Not Able to Port Forward
I've moved a TCP Server application behind my R8000.
My Client software attempts to connect using the WAN address associated with my modem.
Port Forwarding is set up to pass any TCP/UDP message to a specific computer (IP address).
It appears the R8000 is not allowing a connection to be made.
I have tried enabling DMZ and disabling NAT filtering.
It acts as if a firewall is preventing communications from coming in.
In an attempt to debug I tried a Client on the same side of the router as the server -- having the client attempt to connect via the WAN address.  I've used wireshark to capture the traffic.
The client issues a TCP connect (SYN) and the WAN returns a RST_ACK -- which I suspect is coming from the R8000 blocking the access.
Any help on resolving this firewall/port forwarding issue I have?
Thanks.
  • Thanks for reply -- issue resolved.
    Turns out Comcast installed a new moden recently and left its modem's firewall active.
  • Retired_Member's avatar
    Retired_Member
    Can or did you test from outside your home network ....Nat loopback is blocked with netgear routers, It's probably working from outside local but cannot be reached from inside.
    • jhinkle's avatar
      jhinkle
      It's not working from outside, that's why I'm attempting to find out why.
      The client is part of a software report package that has been working with my customers for 15 yesrs now.
      The only thing I have done is moved my server application from a paid Hostgater server to my own computer behind the R8000 router.
      Currently, there is no communication with the outside world.
      Any suggestions?
      • jhinkle's avatar
        jhinkle
