anario
Aug 11, 2016Aspirant
OpenVPN error
Hi Guys, Could you please suggest me solution of how to establish connection between my remote machine and router. I added keys to /etc/openvpn/ dirrectory #openvpn --configure client2.c...
ElaineM
Aug 12, 2016NETGEAR Employee Retired
anario
Aug 16, 2016Aspirant
Thank you ElaineM
so now i'm able to connect, but i cant forward vpn connection in our office, also i can't ping from remote network my local machines is there any solution ?
- ElaineMAug 16, 2016NETGEAR Employee Retired
What do you mean you cannot forward VPN in your office?
Can you provide a network diagram?
If you're unable to ping, check for any firewalls.
- anarioAug 17, 2016Aspirant
ElaineM here is my pic.
VM machine is my openvpn client and i'm successfully connected to office2.
My machines pc1,pc2,pc3 unable to access network 192.168.100.0/24 through VM.
i added route to my pc's 192.168.100.0 gw 192.168.80.81
net.ipv4.forwarding = 1
any ideas ?
Thank you.
- ElaineMAug 18, 2016NETGEAR Employee Retired
The problem lies now on the the VM configuration.
It might be possible that there's a NAT or any firewall of some kind that might be preventing it.
You may want to check the manual of your VM or their community as well.
