chopin70's avatar
chopin70
Virtuoso
Nov 11, 2017
OpenVPN update breaks R7000 and probably other routers VPN implementation
Affected plateforms: Android
Spoiler
Change log that fixed the issue:
Changes from 1.1.23 to 1.1.24:
* relax the certificate validation in mbedTLS to allow certificates with broken date format to connect
* re-enabled deprecated and insecure md5 signature algorithm. Support for md5 will be officially DROPPED on Apr 31st 2018
The previous update broke OpenVPN ability to connect to R7000 VPN.
This last 1.1.24 update of OpenVPN made it again able to connect to R7000 VPN
I am worried about the md5 dropped warning on 31 april 2018.
Are we concerned and is Netgear aware of it so that we do not loose OpenVPN for months before it is fixed on routers ?
  • Hi chopin70,
    NETGEAR is already aware of it. We will provide an update on this concern.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi chopin70,
    • JamesGL's avatar
      JamesGL
      Hi chopin70,,
      Engineering team is working on this but no ETA yet for the release.
      • chopin70's avatar
        chopin70
        Virtuoso
        Thank you
        As soon as we have it working before 31 april 2018, it is ok. So that OpenVPN is not broken
